Massey 250 Hydraulic Problems
   / Massey 250 Hydraulic Problems #1
adamwhite
MF 250
Thank you for the add. I would like to post a question regarding my Massey 250.
Hydraulics slowly stopped working. I changed the fluid and cleaned the filter (both were very dirty). They hydraulics worked for a few minutes then failed, and the low pressure warning light came on.
I assumed my pumps were bad, so I replaced both the primary and auxiliary pumps. Again, I had pressure for about a minute, then lost it. My PTO shaft turns when engaged, so I am assuming I do not have drive shaft or 2 stage clutch problems. I'm uncertain where to check next. Seeking advise please. Thank you in advance.
2017 SKY TRAK 6036 TELEHANDLER (A52576)
2017 SKY TRAK 6036...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52748)
2019 Tico Yard...
2010 KMC 3376 Peanut Combine (A52748)
2010 KMC 3376...
