Massey 250 Hydraulic Problems
   / Massey 250 Hydraulic Problems #1
adamwhite
MF 250
Thank you for the add. I would like to post a question regarding my Massey 250.
Hydraulics slowly stopped working. I changed the fluid and cleaned the filter (both were very dirty). They hydraulics worked for a few minutes then failed, and the low pressure warning light came on.
I assumed my pumps were bad, so I replaced both the primary and auxiliary pumps. Again, I had pressure for about a minute, then lost it. I'm uncertain where to check next. Seeking advise please. Thank you in advance.
   / Massey 250 Hydraulic Problems #2
You may have a split in one of the steel lines under the top cover...
   / Massey 250 Hydraulic Problems #3
Split in the line or faulty relief valve. Unless the draft control lever is in the wrong position...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Toro Workman Utility Cart (A51694)
Toro Workman...
2012 International DuraStar 4400 Service Truck with Crane, VIN # 1HTMKAAN2CH076971 (A51572)
2012 International...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
2020 KENWORTH T680 (A52472)
2020 KENWORTH T680...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
