Saggydog said:
Anyone have any advise on these tractors? I saw one at a dealer up here for $5950 with 2200 hours on it. They have it marked as a 1974 but tractordata.com indicates they were made in 1975-76. Is he overpriced? It looks to be in nice shape. Any info on these tractors would be appreciated. I will be using for bush hogging, garden tilling, and possible a little blade work.
Unless it's in mint condition, that's at the high end of the price scale. They're VERY good tractors except for one issue. The front axle/steering. The 235 was essentially a modernized 135. The 135 was quite possibly the best tractor of its size ever, especially for its day. When the 200 series was introduced, the 235 took MOST of the chassis of the 135 and added different sheet metal, a few cosmetic changes, and an "improved" steering. The steering was "different", but improved it WASN'T. Lighter axle, simple, but not so durable power steering cylinders, and steering linkage that was fine for VERY light duty, but when you consider the capabilities of the rest of the tractor, they just weren't up to the task. Check the front axle center pivot for excessive wear. Check steering linkage for play. If equipped with power steering, check for smooth operation and no leaks on the cylinders. Parts are virtually nonexistant. Some aftermarket or re-manufactured cylinders exist, but get ready for sticker shock IF you find them. Massey Ferguson dealer parts men hide under the counter when they hear "235".
If it's ever had a loader mounted on that tractor, RUN....FAST.... The front end couldn't handle the extra weight. The 235 was discontinued after 2 years of production in favor of the 245. And that 245 was a classic! (It used a steering and axle design essentially the same as the much heavier 255, but parts aren't directly interchangable) The 235 was introduced in the late summer 0f 1974, as a 1975 model. Production halted in mis summer of 1976. Some 245's were sold as 1976 models.
In short, a good tractor with all the bells and whistles that made all the small Masseys of that era great, but with that one liability. Weak axle/steering. If the steering is in decent shape and you're going to be using it for the relatively light duty you describe, they still make a real fine tractor. Just don't abuse that front end. There's still thousands of 235's in service. They have their issues, but it's not a terminal problem.
Should you end up with that 235, contact me via PM. I have a complete set of Massey Ferguson technical bulletins regarding updated service recommendations/retro-fit parts for the 235 steering and axle.
