Loader massey 231 with 232 loader
   / massey 231 with 232 loader #1
samburke
berlin vt
massey ferguson
Hi all I have a 231 with 232 loader that worked fine this summer but now that winter is here the front pump shaft set screws have stripped and the coupling just spins free. I drilled and put a grade 5 bolt in but it broke that when started at 10 below 0 is there a valve that is not working making to much pressuer or is it just water in my pump making it turn that hard when froze I just bought the tractor last summer it was fine till it was time to move snow I would not think there is that much torque on that shaft but so far it does not like winter in vt any thoughts would be great as Ibought the tractor with snow removel in mind but so far it brakes every time its colder then 25 or so thanks sam
   / massey 231 with 232 loader #2
:welcome:
To the forum from Alabama. Sorry about your problem. How old is your tractor and is this the first time you have had this problem?
   / massey 231 with 232 loader #3
How much water is in the hyd. oil?
not shore but hoping to drain it and change it before I start at below zero but if we get more snow that might not be possible the dealer i bought it from SAID they changed all the fuids but I wonder
   / massey 231 with 232 loader #5
I would try to turn it by hand to be sure its not mechanical bound. My Cessna pump was a gear pump and I never had issues on cold starts.
   / massey 231 with 232 loader #6
You can check the fluid
New Holland 273 Hayliner Square Baler (A50515)
New Holland 273...
Corn Reel (A50514)
Corn Reel (A50514)
2007 BMW 750Li Sedan (A50324)
2007 BMW 750Li...
Lull Highlander 1044C-54 Series II 10,000LB 4x4 Rough Terrain Telehandler (A50322)
Lull Highlander...
Split Weight & Wheel Weight (A50515)
Split Weight &...
New 4-235/80R16 Montreal Trailer Tires (A50774)
New 4-235/80R16...
