massey 1705 rops height
   / massey 1705 rops height #1
kubotab1550
brandon
b1550
Looking at buying a massey 1705. A massey pamphlet says that it will fit in a 6ft garage. Measured door height and it is 71" high and yet the rop dimensions are 72.8". I would buy this tractor but it doesn't have a folding rop. I see both Kubota bx and jd have folding rops. Is there a kit I can buy from massey to make the 1705 rop system into a folding one? I've done my research and for its size the 1705 seems like the best tractor to buy.
   / massey 1705 rops height #2
My 1710 has a folding ROPS and I would assume the 1705 to be the same...
   / massey 1705 rops height #3
The 1705 ROPS does not fold because this model does not have a backhoe. My 1705 ROPS would not fit under a 6' garage door.
Sent from my iPhone 2.0 using TractorByNet
   / massey 1705 rops height #4
I would have never thought it wouldn't fold over. Learned something new.
I guess the other option would be to make it foldable with a pin system like on the 1710. As long as the structural integrity is kept, it should work.
   / massey 1705 rops height #5
I would have never thought it wouldn't fold over. Learned something new. I guess the other option would be to make it foldable with a pin system like on the 1710. As long as the structural integrity is kept, it should work.
I suppose you could also purchase the 1715 ROPS and replace the 1705 ROPS as I'd bet they bolt to the tractor in the same place.
   / massey 1705 rops height #6
I own the 1715 model. It doesn't have folding rops. I just measured the height on my tractor, which was 71.5". I have R4 tires on the tractor, turf tires may give a different height.
   / massey 1705 rops height #7
Maybe it's the 1710 and 1720 models that have folding ROPS.
   / massey 1705 rops height #8
The GC1705 and 1715 have a fixed ROPS, the GC1710 and 1720 have folding, because they are taller to accommodate the user when the seat is turned around working the backhoe.
You really have a 6ft garage door? I thought 7' was the standard, many newer homes even go to 8' high doors to give a little more clearance on todays SUVs.
As mentioned, I'd buy a folding ROPS from a 1710/20 and swap them out. Maybe your dealer can work with you on that.
My shop has a lower ceiling thus had to go with 6ft doors, yeh. Im thinking that changing out the rops would be very costly. Guess I'll have to go to another make don't want to but if I get a new tractor it will not be stored outside. Looked at mahrindra today, they look cheaper made, rims on a 2014 were already starting to show rust, and they definitely aren't cheaper. Up here in Canada a 1705 is 13400, jk 1023e 15999 if you buy another attachment and Kubota bx 2360 15500, and mahrindra 24hp 16999. All the mentioned come with fel no mower and all but the massey have folding rops that will fit in my garage. To be honest I haven't even seen a 1705, no dealer in my city but it has the biggest engine cid of them all, that is why I would go for the 1705 then increase the throttle to make it a 1715, so it revs to 3000rpm if needed. If I have to then I will be looking at a Kubota b series, bigger frame etc but also 5000 more, jd bigger frame is 21999 for the 2025r, maharinda 26 is 19999, and don't even know what model the bigger massey is but also I'm guessing in the same price range.
   / massey 1705 rops height #10
A compenitent welder could easily make it foldable.
The Massey is a **** of a tractor, I would not let something so trivial keep you from getting it.
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
Halla LF30C 6,500lb LP Forklift (A51691)
Halla LF30C...
2018 BOBCAT T590 SKID STEER (A51246)
2018 BOBCAT T590...
