Massey 1547 No forward,reverse or PTO ?
   / Massey 1547 No forward,reverse or PTO ? #1
Pokiok
NB, Canada
Massey 1547
My Massey 1547 shuttle shift Dyna QPS has no forward or reverse or PTO working. The range select lever also only shows neutral on my digital dash regardless of which range I select. This just happened all of a sudden yesterday and had to get towed out of the field I was bush hogging. It is a 2008 model year. Anyone have any thoughts as to what I might be looking at? Could it be a sensor, or broken wire, ie:electrical, or is it possibly transmission or clutch?
   / Massey 1547 No forward,reverse or PTO ? #2
I would bet some wires got tugged out of place while you we're cutting. The forward/reverse and pot solenoids are under the tractor near the foot steps. I think pro is on the right/ passenger side and f/r is on the other. That's where I would check first.
Thanks for the response MFRED. Everything looks fine under the tractor, couldn't find any loose or broken wires, any other thoughts?
Problem solved! After determining the for/rev lever function was electronic, I rechecked the fuses and found a 10 amp ECU fuse was actually blown. Sometimes when frustrated its hard to see beyond the end of you nose. Special thanks to MFRED for your input. Happy days ahead cutting again. Love my Massey.
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2015 CATERPILLAR 262D SKID STEER (A51246)
2015 CATERPILLAR...
UNUSED FUTURE HYD MINI EXCAVATOR HEDGE CUTTER (A51248)
UNUSED FUTURE HYD...
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
Massey Ferguson 1734E, 4wd, Hydrostatic Tractor (A52384)
Massey Ferguson...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
