massey 1540 with power shuttle is leaking fluid from the transmission vent tube.
   / massey 1540 with power shuttle is leaking fluid from the transmission vent tube. #1
case310350
Bronze Member
massey 1540 with power shuttle is leaking fluid from the transmission vent tube. Tractor operates fine, maybe a little slower on the shuttle.
Not sure what would cause this. maybe a crack in the casting???
   / massey 1540 with power shuttle is leaking fluid from the transmission vent tube. #2
I don't know exactly how that is setup. This is comparing Apple's to oranges. Allis Chalmers would have some seals go bad and push fluid into the transmission and overfill the transmission. The correct fix was to split the tractor and put in New seals. There are a lot of them running around with the transmission and hydraulics plumbed together ( known as a dirty fix). Maybe something similar going on with your massey. Good luck.
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
JOHN DEERE 700M LOT NUMBER 35 (A53084)
JOHN DEERE 700M...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
LOT NUMBER 51 (A53084)
