massey 1540 hydraulic leak retrun pipe
   / massey 1540 hydraulic leak retrun pipe #1
case310350
Bronze Member
There is a hydraulic leak on the pipe coming out of the filter assembly and going forward to engine. I see there is a rubber hose connecting the two pipes but that connection is ok.
the problem is I have the loader brackets and skid plate blocking my view and cannot determine where the leak is. further more removing the skid plate, looks like I have to remove the loader frame, lots of work especially in the cold weather. Looking for advice.
   / massey 1540 hydraulic leak retrun pipe #2
Give it a really good bath, run it a few minutes and then use an extendable mirror and flash light to locate your leak..... and yes, it is no fun washing a tractor when its cold outside.
Its coming from the transmission breather tube
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
ARMSTRONG  10 FT DISC (A52472)
ARMSTRONG 10 FT...
RV Hitch (A50121)
RV Hitch (A50121)
2023 JOHN DEERE 8R340 LOT NUMBER 221 (A53084)
2023 JOHN DEERE...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
