Massey 1440V - FEL Valve Problem
   / Massey 1440V - FEL Valve Problem #1
torttion
Massey Ferguson 1440v
Hello, I have a MF 1440V with a MF 1466 Front End Loader. About a week ago I noticed a stead drip coming from the FEL control valve. It was coming from under the bonnet on the top spool. The valve is a Nimco 2S-40394 (attached picture). I pulled the valve off, and after found that the leak was most likely due to a bad gasket and O-Ring. I searched online for a replacement seal kit but couldn't find anything. I went to my local Massey dealer and they couldn't find anything on the Nimco valve so were going to call Massey themselves and see that they knew. But, I never heard back from them, so I went down to my local hydraulics shop and he said he'd never heard of Nimco and didn't really seem like he was interested in helping. So, I replaced the gasket and rings with what I thought were similar sized new rings and put everything back together.
After starting it up, I watched it for a bit, and there were no more leaks so I was pretty happy. However, afterwards, I couldn't move my bucket down, I could lift it but it wouldn't go down. I removed the bonnet on the spool to make sure there were no issues from when I put it back together and everything looked good. So, I tried again, and still no luck. In fact, I tried pushing down on the joystick a little too hard and ended up breaking the joystick (the plastick covering the rear stationary ball broke off).
So, at this point, I'm assuming the issue is the new o-rings I installed. And, given that I can't find a seal kit and now also need to purchase a new joystick, I'm wondering if I should just buy either a new valve and joystick combo and a new valve/joystick that all-in-one like the BRAND Model LV22RFSTKAB. Seems like a new all-in-one is the way to go, I'd have to fabricate a new mount but at list I'd eliminate the cables and just be done with it. Any thoughts on why this wouldn't work or suggestions on an alternate route I should take?
   / Massey 1440V - FEL Valve Problem #2
I looked at getting a Nimco valve when I replaced the one on my Kioti. It is run by a couple of women that are not helpful at all. I called several times to ask questions and they would say they would look into it and call me back. Never heard anything back. The also shut down completely often for vacation.
I definitely suggest replacing the valve. I went with a Walvoil and have been very happy. It is a good quality valve that has performed perfectly.
   / Massey 1440V - FEL Valve Problem #3
That one cable adjustment looks way off.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
2024 JOHN DEERE 4044M LOT IDENTIFIER 62 (A53084)
2024 JOHN DEERE...
