Massey 1433 Shuttle Shift forward reverse not responsive
   / Massey 1433 Shuttle Shift forward reverse not responsive #1
Lettusbee67
Fort Collins, CO, USA
Massey 1433
Hi All,
My MF 1433 with the shuttle control is giving me problems. I shift from forward to reverse or vice versa and it doesn't move. If I move the lever back and forth a few times it will eventually change the direction. However problem is getting worse as time goes on. Is this an electrical issue? Mechanical issue with lever? Clutch problem? Not enough oil?
   / Massey 1433 Shuttle Shift forward reverse not responsive #2
I cannot be sure but it is probably similar to my MF2660 shuttle shift. That mechanism has a split pin that holds things together and mine broke or came loose one time years ago. The pin had come loose/dropped out. A washer fell on my foot at the time from under the console. Biggest problem was I could not get in to even look at it much less fix it. Those consoles are made like Alca Traz. Dealer fixed it.
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
Stanley MB3570 Skidloader Breaker (A50774)
Stanley MB3570...
CAR HITCH WHEEL CHAIR RAMP (A51244)
CAR HITCH WHEEL...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
2015 JOHN DEERE 60G EXCAVATOR (A51242)
2015 JOHN DEERE...
