Massey 135 Multi Power
   / Massey 135 Multi Power #1
Texas Blues
Manvel Texas
Massey 1655 Ford 1700 2cyl, Ford 1600 2cyl Massey 135 3cyl gas
Can someone please educate me on a multi power transmission? I keep seeing it mentioned, but dont know what it is compared to a non multipower. My 135 has the 3 speed and hi/lo shifters on it. What determines if it is a multipower? What does it do differently? Thanks, TB
   / Massey 135 Multi Power #2
Multi-Power is another 2-speeds added to your tranny. It's controlled by a lever on the dash, next to the steering column. When you DON'T have Multi-Power, you'll see a piece of trim, OR, a 1/4" wide X approx. 4" long slot in the dash where the lever would be.
MP is hydraulic actuated, but NOT a hydraulic/fluid tranny. High gear essentially over-rides (over-runs???) low range. Low will freewheel while high drives the tractor. Down side? While in low range, the tractor can freewheel down a hill.... You DO NOT use multipower for breaking purposes. It's INTENDED purpose was a shift on the fly hi/low to use while doing heavy pulling chores such as plowing. Back in the day, plowing was one of the, if not THE primary consideration when designing a farm tractor. Not so much these days.
MultiPower was as good as all the rest of the hi/lows of it's day. (My, times change)
Thanks farm. Yea there is a slot on the dash covered with a plate. It sounds like something I would never need. I guess in a way Im glad that I do not have it. Thanks, TB
10' PT Mower (A50121)
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
Ford F800 (A50121)
Ford F800 (A50121)
2014 Genie GTH844 Telehandler (RIDE AND DRIVE) (A50774)
2014 Genie GTH844...
