Massey 135 ignition problem
   / Massey 135 ignition problem #1
meporsche
Northern Tier of PA
Hello,
My 1972 135 (Perkins Diesel) refused to start today. Heard a little static at the ign switch, next time I turned the key, the hot wire to the switch started smoking. The wire was old with bad insulation so I replaced it from the ammeter down to the switch. Nothing. Pulled the plug back off the ign swithc and jumped the contact from the ammeter to the neutra switch. Nothing. Have juice from the hot wire to the neutral switch but nothing going out to the Solenoid.
Figured I had a bad neutral switch but as I closed the engine cover, the jumper wire started smoking. The tractor had been sitting with the jumper connected for almost an hour, no juice flowing. I yanked it out the jumper wire, the wire to the ammeter and to the neutral were both rather warm. So I 'm starting it with a screwdriver right now.
Is it possible that the neutral switch is shorting to ground somehow and causing the wires to overheat? Is there something I am missing? Don't feel like replacing the neutral and still having the same problem.
Anyone have any experence with this problem or knows enough to help me? Thanks to any that can help.
Darwin
   / Massey 135 ignition problem #2
Keep it simple. Make sure the IGN switch isn't being shorted to ground internally. Put Voltage to the trigger on the solenoid. If it cranks then you can assume the starter is ok. Find the lead from the IGN switch that gets power when you turn the key to Start. Run a lead from that terminal to the solenoid. This will bypass all the safety's so do it at your own risk. Once you know it runs you can work backwards checking for bad wires in the safety switches.
1994 Toyota 6000lbs 2 Stage Forklift (A52748)
1994 Toyota...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
Toro Mower (A50324)
Toro Mower (A50324)
2016 GMC Sierra 1500 SLT 4x4 Crew Cab Pickup Truck (A50323)
2016 GMC Sierra...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
198367 (A51243)
198367 (A51243)
