Massey 1233 need Info.
   / Massey 1233 need Info. #1
Hill-64
Alexander City, Alabama
Massey Ferguson-1233
I posted several months ago that I had a problem with my 1233 only having high range. Well I finally got around to breaking it down and found the rear case is busted where the snap ring goes behind two bearings to hold the shaft coming from the transmission to the back axles. I bought this tractor second handed and was told they had put a clutch/pressure plate in it. But as I broke it down I've found silicone indicating the transmission had also been worked on too. There was also a gear stuck on the sub change system. I called and got a price on the rear case ($1,152.00).:( I have a machinist friend that is going to look at repairing it. If it is not repairable does anyone know where I might find a used one in a salvage yard and also was this rear case used on other models which would help my chances of finding one.
( Part# 3709810M5) Any help will be appreciated.
Thanks,
Hill-64
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
19200 (A50324)
19200 (A50324)
