Massey 1230 radiator fan out of wack...
   / Massey 1230 radiator fan out of wack... #1
tz666
Watson, LA
MF 1230
I was cleaning up at the house yesterday, loading trash into the FEL and bringing it to the burn pile and the tractor started making this little bumping noise. It was getting late and I couldnt get the sides of the hood off without removing the FEL so I looked down the raiator fill spot in the top and could see that the fan was not turning true. It was all out of ballance and the noise I was heating was the plastic fan hitting the plastic shroud everyonce in a while. Today I am going to take the FEL off and look into it further. Any ideas or suggestions. Its a 2wd Massey 1230, 25 hp.
thanks
   / Massey 1230 radiator fan out of wack... #2
Could be loose hardware or failed structural component. Start looking at the front of the tractor and work your way back to just behind where the engine backing plate bolts to the transmission housing.
   / Massey 1230 radiator fan out of wack... #3
Not sure how yours is setup.. but if it is a fan on the water pump.. then ya got a bearing going out.
Otherwise.. I'd say a loose hub / hardware..e tc.
soundguy
thanks
Why is the water pump for a 1230 $321.00 and I see water pumps for all other modes for 40-150
the part number is 3710285m93 and I cant find anything about it on the internet
   / Massey 1230 radiator fan out of wack... #5
Compact parts are always more expensive than 1,2,4 and 500 series parts. Take it to a rebuilder to have it rebuilt or your dealer may rebuild them. Most dealers don't but they can send them off. That is by far the least expensive.
   / Massey 1230 radiator fan out of wack... #6
Mornin tz,
Thats what is commonly refered to as "Murphys' Law" ;)
2010 Wacker Neuson Light Tower (RUNS) (A50774)
2010 Wacker Neuson...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
New Holland HM236 3pt Disc Mower (A50774)
New Holland HM236...
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
1267 (A50490)
1267 (A50490)
