Massey 1030 3 point won't pick up
   / Massey 1030 3 point won't pick up #1
dakota1945
Cashmere Wash.
1030 Massey
The 3 point will not pick up with any implement on it. If I disconect it will go up by it self. I no the external hydraulic pump on this unit is fine because I have or had my front end loader conected to it. For now I have hooked it back to orgional to eliminate one question. I had the top cover off, and looked at it, and the piston is fine every thing moves when I move the lever. Help thanks Don
   / Massey 1030 3 point won't pick up #2
Can you install a hyd gage and tell us the pressure at full up on the 3pt lever?
Your 3pt cyl seals could be worn and useless
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
JMR MINI TRAILER MOVER ATTACHMENT (A53421)
JMR MINI TRAILER...
2018 John Deere 460E Articulated Dump Truck (A55218)
2018 John Deere...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A55218)
Ditch Witch 6510A...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
2023 G Bar K Goose Neck Flat Bed (A55218)
2023 G Bar K Goose...
