Masey Ferguson 35 a gaz
   / Masey Ferguson 35 a gaz #1
Dominique R
Masey Ferguson 35 a gaz après avoir tout changer le problème semble électrique , aq
uoi sert le fil sous le système du cap distribution ?
   / Masey Ferguson 35 a gaz #2
Masey Ferguson 35 gas after changing everything the problem seems electrical, what is the wire under the distribution cap system for?
   / Masey Ferguson 35 a gaz #3
The only wire I can think of is the wire on the capacitor/condenser
willy
   / Masey Ferguson 35 a gaz #4
Are you just replacing the old wires or are you also adding something like modern fuses or circuit breakers?
_____________
The mood is “charge the tractor and spin the slot here ”. Perfect evening
   / Masey Ferguson 35 a gaz #5
I only translated the OP's original query to enable some visibility. Not aware if the OP can translate responses.
2015 Dodge 5500 4X4 Bucket Truck (A53472)
2015 Dodge 5500...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
