Pretty much decided on a flail mower. Looking hard at a Vrisimo RSS300-96.
Like the width, the unit is well matched to my tractor (JD5095M, 95hp with PTO @ 80HP), like the broad
range of cut height (2" - 10") since I will need clearance on rocks. Also like the fact that it can be built
with hydraulic offset.
Now I start looking at the Maschio line. Their Giraffa series is a bit narrower in cut width than I would like, but
has the added benefits of offset as well as the ability to mow ditches & small sloped boundaries. Curious thing is that
despite the additional hydraulics, the Giraffa is considerably lighter than the Vrisimo. I am assuming that the Giraffa would be
more versatile since it can do flat fields as well as angled or ditch work. Most of the work will be flat, but there are some areas
along our driveway that are sloped and would benefit from the Maschio capabilities.
Primary use will be mowing fields & crop fields with some brush at times, particularly on the boundaries.
What am I missing?
Does anyone have experience with either of these series?
Thanks,
What am I missing?
Thanks,
