Tiller Maschio tiller
   / Maschio tiller #1
Ronzonie
Massachusetts
Kabota B7800
I have Maschio W125 tiller with an optional slip clutch on a Kubota B7800 The owners manual does not say how to set the slip clutch.The tractor stall instead of the clutch slipping. Does anyone have the adjustment.
This forum is a great sorce if infomation. Keep up the good work guys!
   / Maschio tiller #2
I have a Maschio 72" tiller. If it is the same clutch, it should be set from the factory at 40hp to begin to slip. To loosen, back the bolts off on the springs. I'd go about 1/2 turn on each and try it then. Somewhere I have a chart that tells how many mm out for each hp setting. It's buried with everything else here. I do remember that it came at 40hp PTO power to start though.
Loegering Metal Skidloader Tracks (A50774)
Loegering Metal...
1994 Alumatech Frameless Dump Trailer (A50514)
1994 Alumatech...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2014 Ford F-550 Altec AT37G 37ft Bucket Truck (A50323)
2014 Ford F-550...
John Deere LX5 3 pt Rotary Mower (A50515)
John Deere LX5 3...
