Maschio Tiller Leak
   / Maschio Tiller Leak #1
Guoseph
Lodi, CA
Massey Ferguson 135
Hi all,
I have an old Maschio tiller, I think model L120 from the serial plate. It's leaking from the axle on the inside of the tiller. I looked for a manual online but could only find an L125 and it doesn't look like the one I have. Do you guys know what I would need to replace and where I can order the parts?
Thanks,
Alex
   / Maschio Tiller Leak #2
In the top picture it appears the seal is shot and needs replacement. I would recommend the bearing be examined too as it may have caused the seal to fail. You should be able to take the bearing and seal to a bearing house and get replacements over the counter. I use Motion Industries for most of my bearings, seals and packing for hydraulic cylinders. There are lots of similar businesses to obtain what you need, might try NAPA too.
In the bottom picture I don't see any grease on the Ujoints, might wan't to check these out too. I am changing mine out this week and the cost was about 26 each at NAPA.
Thanks for the motion industries recommendation. Hopefully the bearing is still ok, those things are expensive.
Do I have to remove everything on the chain side to get at this bearing and seal? Or can I unbolt it from the inside (where it is pictured)?
-Alex
   / Maschio Tiller Leak #4
Without seeing it up close I would think you need to disassemble the shaft to get to the seal and bearings. The bearing I would guess is about $45 or close to it.
Pull-Behind Rotary Brush Cutter PTO Attachment (A51691)
Pull-Behind Rotary...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51691)
2019 Ford F-550...
