Martin meteor sb75
   / Martin meteor sb75 #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
I am waiting on delv of a new Kioti Dk50 se HSt tractor. The dealer wants to sell me a new MM sb75 3pt blower for $3100{dealer claims 3900 normally). The weight on this blower is 750lbs. It seems to outweigh all other brands of the same size by quite a bit. I seen some good and bad comments out there. Is this something I should jump on. Thanks
   / Martin meteor sb75 #2
I'm not sure of the price but the SB75 is likely basically the same as my Meteor SB75 P/T (pull type). I have had it three winters and am pleased with it. It gets a fair amount of use since I regularly clear 4,000' or so of driveways. I think it is a very tough snowblower. But I did manage to put a small bend in the auger this spring when it hit a rock on a neighbour's driveway. I still need to fix that before next winter. I don't think it was any failing of the blower. The shear bolt broke as it should but I think the way the rock temporarily lodged between the centre auger support produced huge momentary stress. It also bent the very thick auger support and I could see where the rock must have been on the housing. I have broken the auger shear pin a couple of other times with no damage.
It is a good blower. The basic price July 2011 (with $129 manual chute rotator) for my SB75 P/T (which is more expensive than the push-type) was $3,788). Adjustable skid shoes added $119 and the hydraulic(instead of manual) chute rotator added $598. So my total was $4,505 before taxes. I seem to recall that the push-type equivalent was about $700 cheaper.
For my situation a pull-type or a front blower was all I considered because of the driveway lengths. So your first step should be to decide what type of blower you need. When researching mine I found it easy to get LIST prices from the manufactures, and I found the dealers stuck close to those prices.
One thing....it is good to order a blower in early summer to ensure delivery for winter. Even though ordered in July, mine just made it for snow season. To a lesser extent the same is true for tire chains.
   / Martin meteor sb75 #3
I have had my SB51 for 4 years and it works just fine. It is a push type.
Many comments and concerns about the Meteor have talked about the gearbox. Some folks have had broken shafts on gearboxes that were a real expense and problem. I do know that two types of gearboxes were used; 1-1/4" spline input shaft, and a 1" keyed input shaft. The splined shaft has not had any problems that I can recall.
I recently changed my gearbox oil and stripped the plug-- my fault. I am in the middle of that repair now but I expect to have it done pretty soon good as new.
   / Martin meteor sb75 #4
I had one for a few years, sold it due to issues with my back.
Overall it was a decent piece of equipment. I did add extra holes for the spout, the factory ones either threw the snow down or launched it **** near vertical. I thought it should've thrown the snow farther also.
I would buy something else next time.
Ed
   / Martin meteor sb75 #5
I have a 2012 SB75. It is a very robust unit. My only complaint is that it only blows snow 28 feet. Yup No BS that's it; I measured it a few times and that's at FULL throttle (570 RPM). I would not buy another just for that reason. My next blower better launch snow at least 100 yards :)
Fred
   / Martin meteor sb75 #6
I'm still shopping for a tractor. The Kioti dealer, who has me looking at a DK40SE suggested the SB75 to me, saying I would want it's width for the turn in my driveway. I'm a little skeptical that the 40hp will handle it...any thoughts?
   / Martin meteor sb75 #7
It will easily handle the SB75. I have the 75" pull-type on my DK35SE HST and it handles it well. You would not want a smaller blower with that DK40.
   / Martin meteor sb75 #8
The MK Martin site has a specification table that says the recommended HP for the SB75 is 50hp. An ad on eBay says the SB75 should have 50hp for efficient operation.
   / Martin meteor sb75 #9
I had the same concern when I bought my SB75 pull-type. My dealer assured me the DK35SE (27.5 hp PTO) would handle it, which it does. The DK40SE @ 32.5 hp PTO will easily run it. The fan blade size and number has as much influence on power requirement as the overall width. Compare the hp requirement with others such as Lucknow, Erskine and Normand. They give different hp requirements for similar blowers.
My clearing typically less than 12" of fairly dense snow. I believe your area may get deeper snows. If a snowfall is very deep you can just go a bit slower.
   / Martin meteor sb75 #10
It was the spec sheet that I saw which caused my concern, and when I questioned the dealer he said the DK40 would have plenty of power without issue. But it's always better to get real-life referrals! Thanks kco.
2008 Wells Cargo T/A Enclosed CERT Trailer (A50324)
2008 Wells Cargo...
1998 Volvo VN T/A Dump Truck (A50323)
1998 Volvo VN T/A...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52748)
Hay Van FL-95 Bale...
