marking self level for bucket
   / marking self level for bucket #1
kully
Bronze Member
upper ny,and long island
kubota m4900 with loader
so I have a kubota m4900 with the la1002 loader and I keep having trouble with the paint staying on the level arm that rides up and down the tube. it keeps comming off , what does everbody use for marking .
   / marking self level for bucket #2
I had the same problem and did two things to solve the problem. First, I removed the rod and used a small conical shaped grinding stone on an electric grinder to shape and hone smooth the interior top edge of the tube such that there was no abrupt sharp edge to score the paint. Secondly, I used a small lathe to knurl down the rod a few thousandths where the marker line is located on the rod. I then repainted the marker line with a quality fluorescent epoxy paint. With the sharp edge on the top of the tube removed and the marker stripe below the surface of the rod itself the marker has remained perfect for the past few months.
Ken
   / marking self level for bucket #3
I cut my level rod off so when the rod is level with the top of the tube the bucket is level.
   / marking self level for bucket #4
That's what I did also on my JD:D
   / marking self level for bucket #5
I just put a ring around the tube with a magic marker. Still there after a year.....
   / marking self level for bucket #6
I used a magic marker... one ring for absolutely level
another ring for bucket front edge 1 inch off ground
another ring for bucket digging in at slight angle
Yep, they get a little beat up but still usable... I like Ken's idea .. I need to do that!
   / marking self level for bucket #7
I wrapped electrical tape around mine. It's been there for about six years.
UNUSED MOWERKING SKID STEER HD FLAIL MOWER (A50460)
UNUSED MOWERKING...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A50397)
Kubota 24in Quick...
2013 JCB 515-40 3,300LB 50 HP 4x4 Rough Terrain Telehandler (A49346)
2013 JCB 515-40...
42in Hydraulic Forks Forklift Attachment (A49346)
42in Hydraulic...
2008 GMC Acadia SLT1 SUV (A48082)
2008 GMC Acadia...
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A50459)
JOHN DEERE 975 3...
