Marking high & lows while mowing/brushcutting
   / Marking high & lows while mowing/brushcutting #1
Wormwood
Bronze Member
Little Rock, Arkansas
Kubota M5-111 SVL97-2 KX080-4s2
Is there any product that you can attach to a tractor to mark places in a field or yard? I'm using a marker paint extension wand to mark places I need to fill in with dirt or scrap off the top as I run over them with the tractor.
I was thinking of something attached behind left or right rear wheel aimed down at the grass. Bump a momentary switch & it sprays the ground for you. It would allow me to keep both hands on the wheel and not have to hold the extension wand constantly.
Thanks,
Wormwood
   / Marking high & lows while mowing/brushcutting #3
A thought brought on by stuck motors post. How about a tank sprayer with a dye. Rig up some sort of valve for under foot. Maybe the sprayer trigger then hose to ground.
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51692)
2023 Stryker...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
One pallet of miscellaneous items (A53117)
One pallet of...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
