manure spreder
   / manure spreder #1
schmism
Super Member
Peoria IL
New holland TC(33)
How much manure can you spred on pasture/hay feild?
you guys talk pounds per acer? number of application times per year?
My old neighbor has about 15 horses in way to small a space. He has quite a few piles of manure out back, and was considering spreding some on my 3 acer front "hay feild"..... which is then cut on shares. (and i think im going to continue to have done)
This came up for $450.... "working condtion, good floor"
   / manure spreder #2
During the winter, I spread around 120 bushels a week (30% manure 70% shavings) in my Tifton 85 hay field. I try to spread it in a different place every time and after a few good rains you really can't see it. I've stopped using that field now that I've fertilized and it's greening up. During the summer, I'll use one of my bermuda fields that I won't bale as much and switch to a cow pasture a few weeks before cutting & baling.
In my case the horse manure is not a problem...the spreader breaks it up pretty fine. The issue is the pine shaving that we use for bedding in the barn. It takes longer to breakdown and sticks in the bales. If you're just spreading manure, it wouldn't be much of an issue other than the tire tracks and ruts you'll put all over your field while spreading it.
   / manure spreder #3
That spreader looks like mine used to...have had it for 12+ years and still works fine except for a fender that I need to repair and reinstall this summer...and I paid about that much back then, so if it's in good condition I would say that's a decent price.
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
Chevrolet C8500 Flat Bed with a Moffet Kit (A55218)
Chevrolet C8500...
2018 Ford Transit 350HD Handicapped Van (A53422)
2018 Ford Transit...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
