Manure Spreader
   / Manure Spreader #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I ended up ordering a Frontier 1108G. It works great. Pulled it with my Polaris Ranger Crew and loaded it with the JD 4720 FEL.
As required - here are pics.
D.
   / Manure Spreader #2
Looks like a good basic spreader. How do you like it?
Without a doubt I wish I had your equipment buget!!!!
Good luck with it.
Dave
   / Manure Spreader #3
Darin, how did it pull behind the Ranger? I'm a bit torn between ground driven vs. PTO. I am leaning towards a ground driven for the exact reason you got yours . . . so I can pull it behind a UTV and load it with the DK.
Any pictures with it near/next to the 4720 . . . for size comparisons?
   / Manure Spreader
Good luck with it.
Dave
It works great. It is the largest ground driven model Frontier sells. I really didn't want a PTO powered one. I just use it to clean up my pastures where I hay, and the barn when I have a sick cow or so in there.
Equipment budget? ****, the B word again.
D.
   / Manure Spreader
The ranger pulled it just fine. 4wd in low and it goes. You can tell it has a load on it when it is full. No pics with the 4720 next to it. I can shoot one of those later. I put the spreader in the shed, but I can put a tractor next to it for comparison.
About 5 full bucket loads it what it will handle. This stuff was wet, nasty, etc. The ranger was squatting some when I put the first load in it.
It is hard to tell from the pics, but the beaters are made of heavy duty steel. For some reason I thought they were plastic or something. The unit is much better quality than I first imagined.
Now, with that said it sits very low. Getting it on and off a trailer is a hassle. I will use my tilt bed next I need to move it. It can drag on the gear box in ditches, etc.
All in all, I think I made the right decision with this unit. I spent around 3-4 hours spreading a couple mountains of crap.
D.
   / Manure Spreader #6
Good info D. Sounds like the type/size unit I need. Do you still have your Gator HPX or are just using Ranger. I assume the HPX will pull it too?
   / Manure Spreader
I still have the Gator. It is at the JD Dealer - hoping to be sold soon. I believe it would pull it just fine. I pulled a 16' trailer full of stuff many times with my ole Gator without an issue.
D.
   / Manure Spreader #8
We have a 50 bushel Frontier (1105?) that we pull with either our Gator XUV or JD 870. The gator has no trouble pulling ours. These small spreaders can be very handy!
2009 Freightliner M2 106 Ambulance (A51692)
2009 Freightliner...
2018 Freightliner Day Cab, Detroit Diesel (A52384)
2018 Freightliner...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
2003 Ferris IS1000 52in Zero Turn Mower (A51691)
2003 Ferris IS1000...
