Oil & Fuel Manufacturer's Rep.
   / Manufacturer's Rep. #1
GDunlap
For those of you want a cross reference to Kubota UDT oil go to schaefferoil.com; select technical data; scrowl down to and click on 0315 Simplex Supreme; go to page two, column two and you will find Simplex Supreme meets Kubota UDT specs.
   / Manufacturer's Rep. #3
I've found that most oils have to go by the standard testing for equivelents. It doesn't mean that the sae is the best possible spec oil, just a base to work from!
Funny I even remember a few years back some great priced oils were booted off the shelves when they were found to not meet the minimums.
   / Manufacturer's Rep. #4
most all hydraulic oils meet UDT, its SuperUDT that has no equilivant.
The tech sheet the OP points to indicates it's also an equivalent for SUDT. The web site is pretty hard to figure out, I couldn't find a price for this oil. And without the original pointer from OP, I wouldn't have been able to cross reference kubota oil.
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
(APPROX 72) UNUSED LANDHERO WHEEL STOPPER (A51248)
(APPROX 72) UNUSED...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
