Manual says
   / Manual says #1
AUSTENNN10
Alto nm
Ls 3033
Front tires 17.9 psi
Rear tires 50 psi
The tires say on the sidewall
Front 50 psi max
Rear 20 psi max
Almost got me
   / Manual says #2
You can actually read and decipher your manual? :)
   / Manual says #3
If your not running filled tires and you have a loader, I'd say anywhere between 25-30 on the front and 30-35 on the rear.
   / Manual says #4
LOL! I did that when I first bought my tractor.
Vely broken Engrish I think.
   / Manual says #5
FYI:
The Owner's Manual states what the tires should have in them.
The Tires state on the side what they are capable of handling.
The two numbers do not always coincide. The Owner's Manual, though, should be less than or equal to what the tires are rated for - never over.
   / Manual says #6
My selling dealer must have read the same book.
All my tires were at 50 when I brought it home. They were supposedly checked by the mechanic during the pre-delivery inspection. Needless to say, after finding the tires at 50 I rechecked everything on the pre-inspection list.
Fronts are now about 40, rears are filled and at 18 PSI.
   / Manual says #7
My manual had the pressures higher too. I checked the tires and read the imprint on the tires. Rechecking the manual they were listed as 8 ply not the 6 they were.
2015 CATERPILLAR 279D SKID STEER (A51242)
2015 CATERPILLAR...
2015 Polaris Sportsman 570 SP ATV (A50514)
2015 Polaris...
Gehl Mix-All Mill (A50515)
Gehl Mix-All Mill...
2018 BOBCAT T450 SKID STEER (A51242)
2018 BOBCAT T450...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
Livestock Stall Fan Cage (A50515)
Livestock Stall...
