mantis carb settings
   / mantis carb settings #1
simonmeridew
Northeastern Vermont
Kubota L4400
does anyone know what the H and L needles settings should be on a 2 cycle Mantis? I've opened them both 1 turn from gentle seating but I don't want to lean it out too far. It won't 4 cycle like a chainsaw.
simonmeridew
   / mantis carb settings #2
H and L are the High and Low speed mixture adjustments. Unless the needles have been jammed closed, most 2-strokes will start at 1-1/4 to 1-1/2 turns out, but consult your manual if you have one.
   / mantis carb settings #3
I found a mantis manual and the base settings are not given, you could try searching by the engine manufacture for the info.
Dose the carb have limiters on the h l screws? Or have they been removed?
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
17101 (A53421)
17101 (A53421)
2016 John Deere 326E (A47477)
2016 John Deere...
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
