Making an older skid steer 'auto stop'
/ Making an older skid steer 'auto stop' #1
anesthes
Bronze Member
Salem, NH
Mahindra eMax 22
I bought an old Ford (made by erickson) CL340 skid steer. It's a cool little machine, however with the controls in the neutral position it rolls. It is designed with a service brake pedal to stop it.
It's a typicl (I think) setup with hydraulic motors and chains on each side to control the wheels.
For you folks who know more than may, can you give me any hints or help getting it to 'stop' in the neutral position like a modern bobcat skid steer?
The previous owner uses power forward and back to stop/slow it, however if the engine stalls and you are on a hill it's all over.
The service brake, while with some new pads could provide reasonable stopping, cannot be locked either so if you exit the machine it will again - roll down the hill.
Thanks!
-- Joe
/ Making an older skid steer 'auto stop' #2
Hey Joe,
Welcome to TBN.
I did a little research on your machine. From what I saw just looking at the parts diagrams, there's not much way to give this machine static braking capabilities.
The parts list shows the hydraulic drive system using a gear pump, a metering valve and a drive motor. They don't say what kind of motor and don't show a break down of the motor so it could be a gear motor, a piston motor or an orbitrol motor.
When a gear pump and metering valve are used to power a motor, the valve usually has what's called a "motor spool" in it. This allows free flow of the oil when the valve is in the neutral position. The oil is not blocked in any way so the motor has no braking effect. The reason for the motor spool is to allow the motor to come to a stop slowly and freely so as not to damage it. Just imagine if the motor was turning full RPM's and the valve suddenly closed and trapped the oil. It would have nowhere to go so something would have to give.
Your best bet would probably be to repair the brakes on your machine.
Hope this helps.
Mark
Hey Joe,
Welcome to TBN.
Hope this helps.
Mark
Hi Mark,
Well you sure do know a lot more about hydraulics than I do!
Thank you for taking the time to review my question. sounds like I will just repair the service brake. My big issue with the braking system is no parknig break. My oliver is set up so you can press the brake pedals and lock them in place, so you can exit the machine and do something. I will have to review the parts illustrations and see if their is missing parts.
Curiously, how does hydraulic braking work on a bobcat?
I have one last question. This machine runs pretty well, but does have a little blowby and oil consumption. The selling price was reasonable, and lower than most machines with missing engines so I took it.
The seller has a "spare" 30hp wisconsin engine (same engine that powers this, he believes) that he wants to sell for $250. Would you recommend me picking up the spare engine, or holding out until this machine breaks down and replacing the air-cooled 30hp engine with something better?
-- Joe
/ Making an older skid steer 'auto stop' #4
Joe,
I looked all over the parts catalog and I couldn't find any parking brake mechanism either.
You can go to the Ford/New Holland website and see the parts catalog online.
NEW HOLLAND CONSTRUCTION | BUILT AROUND YOU
Just click on the red link that says, Parts Catalog, then type in your model number. It'll show you the complete parts catalog.
Static breaking on newer skid steers is done through the hydrostatic drive which is a completely different set up than your machine has. Hydrostats use piston pumps and piston motors. Normally the pumps are variable displacement, meaning they can put out different amounts of flow and pressure from 0 to their rated capacity. Piston motors can be fixed displacement meaning they have a specific torque and speed at max input, or variable displacement, meaning the torque and speed can be varied without varying the flow from the pump.
To get static braking with hydrostats into a nutshell, the oil is trapped between the motor and the pump. There is no control valve or metering valve between the two. When the levers are in the nuetral position on the drive pumps, the pump is set to 0 flow so the oil trying to get out of the motor is trapped, giving the machine some braking.
Most people don't realize that static braking like this is not complete and total immobility. IF the motor is worn there is chance that internal leakage inside the motor can allow the oil to bypass and the machine can move. It won't move fast, in fact it's barely noticable over short periods of time, but I have seen machine with hydrostats and static braking that would creep down a steep slope overnight.
If you can get a good used 30hp replacement engine for your machine for just $250 it would make good sense to get it. I'd see and hear it run before I bought it to make sure it was a good running engine. But you can't even begin to rebuild a Wisconsin for that price, nor could you convert to liquid cooled or diesel for that price.
Joe,
Ok I'll make sure I can hear it run and pick up the spare engine.
I created an account on that website, but I can't seem to locate the CL340 ?
-- Joe
/ Making an older skid steer 'auto stop' #6
Joe,
I didn't have to create an account......
Try this link and see if you get to the parts catalog.
There'll be a box in the upper left corner of that page that says "Model".
Just Type in CL340 and hit Search. Should bring it right up for you.
Here's the link.
https://webparts.pvassociates.net/cnh/launch.php?DealerID=PVA-9SYXB-QHF3&DataSet=001NHC
You may have to go through a verification page first to get to the parts catalog.
Mark
/ Making an older skid steer 'auto stop' #7
The parking brake on most old equipment is putting the loader to the ground and lifting the tires.
You probably could convert the motor spool to something else with a relief valve in it and a damped pilot type circuit so you can't change direction fast enough to break something but we're talking hundreds of bucks and maybe custom machined valve block to install the valves in.
Joe,
Here's the link.
Mark
That worked, thanks a bunch. I just bought this thing and i'm dragging it home this weekend. Hopefully it will be a good replacement as a manure mover compared to my 1958 Oliver 550! :)
Thanks!
-- Joe
So I've been playing with this thing a little bit. I like it but some things I noticed:
1) It jerks and jumps a lot if you give it too much umm. push forward. I hit my head on the roll cage. Operator error there, but I wonder why the jerkyness.
2) The foot gas pedal can't be in a worse spot. Horrid design. I'm going to mount a throttle lever on the side.
3) The ignition, gauges, start switch, and choke all need to be mounted at the hood of the cage, not between my legs. It's almost impossible to start it without having a knee into one of the controls!
4) No toe guard. After only brief ownership, I almost lost my food putting the loader down because my foot creeped beyond the front step into the path of the loader cross bar. I'm going to have to weld up something to keep from that happening!
5) I'm not sure if the best thing to do is turn the machine off before exiting/entering, or develop some sort of safety but it is impossible to get in or out without bumping the controls and lurching forward or back. The loader is controlled by the top of the joystick, so it's not as scary as a bobcat or something with foot pedals, but the fact that you can run yourself over isn't cool. I know sometimes when working you need to jump out and move something quickly.
-- Joe
/ Making an older skid steer 'auto stop' #10
another option one could use is a high pressure hydraulic, ball valve in the line that one can just turn when you stop to get out,
/ Making an older skid steer 'auto stop' #11
First I'd look at lateral adjustments. Get a service manual and usually you can do it yourself. It's pretty simple in theory. Other than that then shut the machine off. SS are just not as safe as tractors to be able to be able to get out with them running. I have an older Bobcat 742B and the parking brake is shot on it. I'll get around to fixing it eventually but until then because mine creeps a little also I just shut it off to get out.
Good luck.
/ Making an older skid steer 'auto stop' #12
In the mid 70's I worked at a place w/ a Case Uni-loader. They did not have any sort of brake. The drive used two clutch mechanisms on each side for forward and reverse using chains between the output and to the drive wheels.
The engine drove a two speed [hi-lo] gearbox with the output split right & left, no hydraulics for propulsion...
It was herky & jerky to drive and you had to put the bucket on the ground to hold the machine when you got out.
It was still a neat machine, would turn in it's own length and the more you used it, the smoother you could operate it.
I remember backing out of the shop and letting it freewheel down the slope & pushing both sticks forward to pop a wheelie, letting off on the side where you wanted to go and it would swivel around while still on the back wheels...
Do you guys know where I could still get parts for these? The master cylinder (brake) is junk. Totally rusted. It's erickson part # 27029 and I can't seem to find one online.
-- Joe
/ Making an older skid steer 'auto stop' #14
dont know if you still have the cl340 that you asked why it rolls in neutral it should not roll this means your drive motors are gone does it jump when you push levers to dive forward i need parts i have drive motors you can call for more info grover 603 6622577 excetas@yahoo.com
/ Making an older skid steer 'auto stop' #15
Did you tract down a replacement master cylinder for your 340?
I just purchased one and the MC is bad. Not having much luck with the Erickson part #.
/ Making an older skid steer 'auto stop' #16
The date on the earlier posts are 3 years old
/ Making an older skid steer 'auto stop' #18
Hello so I have a new to me cl340 and one side does not lock up (left). I found a used motor I was told was good and put it in but it still free wheels on that side and I am wondering if its something else like the control valve that allows the fluid through the motor. When I'm moving forward or backwards with both levers engaged and I put the left side in neutral it still moves basically straight but makes a winding sound like fluid is being forced through...
Any thoughts?
UNUSED IRANCH 23" GRID SHAPED MINI EXCAVATOR BKT (A60432)
UNUSED IRANCH 23"...
2015 CATERPILLAR 308E2CR EXCAVATOR (A60429)
2015 CATERPILLAR...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-150...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
