Making a pond questions, mainly keeping mosquitos from breeding
   / Making a pond questions, mainly keeping mosquitos from breeding #1
etpm
Veteran Member
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
My wife and I have been talking about me digging out an area we have that already ponds every winter and making it permanent. And larger. The area is in the woods behind our house. Because of the way the land is I could excavate and pile the dirt around part of the perimeter and end up with a pond about 12 feet deep and about 50 feet diameter. Overflow would not be a problem because higher land on our property would keep the water from leaving our property. So there is no worry about flooding neighboring properties. Our house is about 30 feet above the pond so the house would not be threatened either.
The area that ponds now is fed by rain and ground water only. I think I can dig the area out and seal the pond with bentonite. I have a Case 580CK that I would do the work with. I have been reading books and government publications about building ponds. But I have never communicated with anybody who has actually put their own pond in.
One of my biggest concerns is keeping the pond from turning into a big mosquito breeding facility. I have plenty of small frogs living in our woods and I'm sure they would love a year round pond but I have no idea if they would keep mosquitos at bay.
I live in the PNW about 30 miles north of Seattle on the south end of Whidbey Island. Maybe that info will help with suggestions. Besides frogs I was thinking fish and crayfish might also be beneficial. I could trap crayfish in a lake that is close to me and transport them to my pond if they would live. Ducks and geese may find the fish tasty and so maybe there goes that control method.
I am willing to put in some sort of aerator for the fish if needed, but I was hoping the pond would be big and deep enough to not need one.
Since the pond would be in the woods it would get a lot of shade unless I cleared trees around it, which I am considering.
So, looking for suggestions.
Thanks,
Eric
   / Making a pond questions, mainly keeping mosquitos from breeding #2
Fish will eat mosquito larvae. Also if you can install a waterfall or fountain in the pond to keep the water moving, mosquitoes won’t be a problem. Crayfish will make your pond muddy.
   / Making a pond questions, mainly keeping mosquitos from breeding #3
Try researching fish for keeping misquotes at bay in ponds . Some species may be better than others .
   / Making a pond questions, mainly keeping mosquitos from breeding #6
You are on the right track with stocking fish from your area rather than importing some that might not adapt. I would go for diverse species and let nuture decide which floresh and which struggle. Give them a place to escape/hide from water fowel. We place Eastern Red Cedar ( Juniperus virginiana L.) in ponds we build for cattle. They have small,dense limbs that take longer to rot than most other trees.
   / Making a pond questions, mainly keeping mosquitos from breeding #7
Frogs and toad tadpoles here get a lot of them in a pond / puddle situation. Small fish also do a wonderful job if the pond is one which will retain water year long.
As for moving water ... well here mosquitoes happily breed in rain water tanks which have a roof powered water feature during the rain season here, when much of the day is drizzle. Not every mosquito breed is the same, no doubt some would be more picky or careful where to lay eggs - there's no point feeding fish in a nice stream.
BTW, dams and ponds don't generally tap into underground water streams, so do not add to any flooding burden downstream unless the wall breaks. I'm sort of amused when some people tout such things about dams causing flooding downstream ... a bit like that picture of a bloke on the back of a truck tray helping push it.
   / Making a pond questions, mainly keeping mosquitos from breeding #8
Mosquitos like stagnant water that isnt sufficient habitat for frogs and fish.
An actual pond with its own life and ecosystem...fish frogs and birds....mosquitos wont be an issue
   / Making a pond questions, mainly keeping mosquitos from breeding #9
Thanks,
Eric
The number one thing is water turnover or moving water. If you get plenty of rain and you have an overflow you should be alright.
   / Making a pond questions, mainly keeping mosquitos from breeding #10
Thanks,
Eric
Minnows will help with mosquitoes. Bats are the best thing for eating them. But if you have standing water anywhere, you will have mosquitoes.
Bentonite is an expansive clay that has to be mixed in with the soil and compacted. Disk it and drive over it a bunch of times should work. The amount of bentonite that you need will depend on the soil that you are dealing with. Bentonite is not water proof, it gets bigger when it's wet and seals up what you have if it's able to hold water. You cannot expect it to do anything in sand or loam.
I dug my small pond with a 555E backhoe. Digging is easy. Hauling it off takes forever!!!! When I was about halfway done with my pond, I just started piling up all the dirt right next to my ramp out of the pond so I could be done before winter rains hit. I had a pump to get rid of the water from rain while I was digging. It was warm enough to dry out, and I had a low area for the water to go to while I was digging in a higher area. The ramp is the most important part of digging with a backhoe. It will only go up a slope so steep without spinning the tires or bogging down. On my small pond, I make the ramp go from the middle of the pond, up the side. When I dug my big pond, and I had a dump truck, I made my ramp run along the edge of the pond so it was longer and had less of an angle.
After you are done with it, and the plants start showing up out of nowhere, you will eventually have fish in it that you never put in there. Mother Nature will do this. I believe it's from Herons and Cranes that go from pond to pond. I think that fish eggs get attached to their feet.
I don't know what the laws are there, but a friend in California wanted a pond on his land and the county refused to allow him to do it. He looked all over his place and found a spot where a pond used to be. He didn't need a permit to clean up and fix an existing pond. Only to build a new pond. It's very important to avoid violating any laws, so you should be fixing and repairing an existing pond that has filled up with silt, over grown with trees and brush, and the dam failed, to stay legal. It's not your job to prove to them that there was an old pond there before you rebuild it, it's their job to prove it was never there before. In my friends case, his old pond was from the 1800's, and they didn't have aerial photos going back that far to prove it wasn't that old.
Informational Lot - Financing (A52128)
Informational Lot...
2024 WABASH STEP DECK TRAILER (A51222)
2024 WABASH STEP...
Parker 250 bu Gravity Wagon / Seed Tender (A50515)
Parker 250 bu...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
