Making 3PH go lower w/Middlebuster
/ Making 3PH go lower w/Middlebuster #1
bcarwell
Austin, Texas
Kabota 7500DT
I have a Kubota 7500 and a new Middlebuster from Tractor Supply. Used it for the first time today and the deepest I could make it dig was about 8 inches with the 3PH lowered all the way.
Could somebody tell me how to get it to go lower ?
I looked in the Kubota manual and there are two holes on each horizontal link/lifting arm. If you hook the lifters to the holes which are closer in towards the tractor you get more vertical movement of tools connected to the 3PH (and less lifting capacity). But just eyeballing it, even if I use these holes which are closer in, it doesn't look like I'd get substantially that much more vertical downward movement of the Middlebuster (though I'm certainly game to try it). I had no trouble digging down the 8-9 inches but it appears I can't go any deeper not becaue of the soil or the Middlebuster, but because there isn't enough downward travel of the 3PH.
Thanks for any help.
Bob
/ Making 3PH go lower w/Middlebuster #2
Moving them in closer to the tractor will allow your arms to drop farther and increase the lift capacity. Give it a try.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2013 Bobcat T190 (A64126)
2013 Bobcat T190...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
