make a strange wining sound when the clutch let ou
   / make a strange wining sound when the clutch let ou #1
VaRandy
Potomac Falls VA
Nortrac 254
I have a 254 with 18 hours on it and fel, backhoe and when I let the clutch out it make a winning sound any help would be great
Randy
   / make a strange wining sound when the clutch let ou #2
Does the noise happen about half way off the pedal and continue when fully released? does it do it in creeper H and L the same?
Yes it does it in H & L only when the pedal is in its last 1/2 inch of travel but stops 1 or 2 sec after release it sounds like it is coming from under the seat not closer to the engine no grinding other than that the trackor seems to work fine
Thanks for any help
Randy
   / make a strange wining sound when the clutch let ou #4
You are probably getting some friction between the PTO shaft and the mainshaft which surrounds it. you might try overfilling the oil in the trans and see if it quits down, you can drain it back down to normal, this seems to help this problem.
   / make a strange wining sound when the clutch let ou #5
It might also be that your clutch throw-out bearing is not fully disengageing from the clutch fingers(clutch pedal free travel improperly adjusted).
What type oil are you running in the gearbox? What is your outside air temp?
Noise locations can be very deceiving on these things since there is so much metal to conduct noises around. I find a mechanics stethescope very helpfull in pinpointing unusual noises(about $5 at Harbor Freight) or a long screwdriver held with one end on a spot on the machine and the other end either against the bone behind the ear(with ears plugged) or against the plastic cup of hearing protector earmuffs.
   / make a strange wining sound when the clutch let ou #6
There is a o-ring that seperates the main shaft and the PTO shaft, we have had a few tractors that this o-ring broke which made the tractors have a whinning sound as you engaged the clutch, you have to split the tractor to replace it. Hopefully thats not it,but it sounds like it
Tommy
Affordable Tractor Sales
   / make a strange wining sound when the clutch let ou #7
Did you ever resolve the problem? I started a new string asking for some info. Thanks
Yes, I did get the clutch problem resolved, no thanks to Nortrac. I will say Nortrac /Northern tool has lost me as a customer foreaver!!! Will give more details later
Randy
2007 Chevrolet Tahoe SUV (A51694)
2007 Chevrolet...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2009 Volkswagen Jetta Sedan (A51694)
2009 Volkswagen...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2016 FREIGHTLINER...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
2015 Honda Odyssey VAN (A51694)
2015 Honda Odyssey...
