Major problem with CC 2042
   / Major problem with CC 2042 #1
keltonkrew
Riverside, Tx (Lake Livingston)
2006 MF GC2300 - 2005 CC-2042 - Honda Harmony self propelled
I've had this mower for a little over 2 years...I find myself using my Massey Fergurson tractor more....the major problem is the beer holder is on the same side as the discharge chute...I get grass clippings/dust in my beer....on the Massey it's on the opposite side! Don't these CC engineers know that we would like nice cold beverages w/out dust/grass on the top :D Other than that, it's be a fine machine!
   / Major problem with CC 2042 #2
The cup holder on the Cub is technically a cup dispenser. You're supposed to leave a stack of cups in there upside. As you are mowing, you remove one cup and dispense beer into it from the refrigerated keg* that you are towing behind you.
*Refrigerated keg sold separately; Available at select dealers only; Some assembly required; Warning: drunken men should not mow their lawn with an open-top cup - a child's "sippy" cup should be used instead to avoid environmental contamination and wasted beer.
   / Major problem with CC 2042 #3
I don't use cups without lids-Problem solved! :cool:
   / Major problem with CC 2042 #6
keltonkrew said:
I use cans so I can recycle!
I use cans also but the dust & clippings still get into the can. Obviously the engineer(s) never thought about the advantage of placing it on the opposite fender.
Bob B.
   / Major problem with CC 2042 #7
LBrown59 uses Sippee Cups :D
well I'm sturborn and will not put it in a cup....so I LET my wife use the Cub and I use the Massey :D
   / Major problem with CC 2042 #9
A pony keg on a rear mounted bracket seems to be the best answer. Those suitcase weights and their bracket are a big waste of $$
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
2014 TOYOTA 8FGCU25 FORKLIFT (A51222)
2014 TOYOTA...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
John Deere 506 3 pt Mower (A50515)
John Deere 506 3...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
