3-Point Hitch Major Modification on LS MT125 3pt Hitch
   / Major Modification on LS MT125 3pt Hitch #1
rider7767
Platinum Member
Paris, TN
TYM T264 with loader and implements
I hated the fact that I would have to take off a tire to put on and off my 3 pt hitch after removing the backhoe. I machined some parts and made it work like a John Deere 1025R TLB. I hope you enjoy the video. I will till the garden tomorrow with it. :thumbsup:
LS MT125 Major 3pt Hitch Overhaul - YouTube
   / Major Modification on LS MT125 3pt Hitch #2
Thanks for the video, looks a whole lot easier. After you use it, make sure you do a follow up of how it worked / held up to stress. Do you think there is another way to do your mod without having to turn down the pin? I don't have access to a lathe and am very far from any shops. I have a bunch of upcoming projects that I will need to switch back and forth: using the BH, then 3pt attachments, then back....Seems like doing that w/o your mod will be a pita! You mentioned your mod is similar to the green tractor's setup, do they sell a pin that we could use (just bolt it on?) or is there another hole that a second pin could be added the opposite direction for the stabilizer? I have not had the time to be able to look at my tractor this week. Thanks for all the videos that you have been doing. Very informative.
You could always use the pins the way they come. You would not have any sway control, but it would work. I am having a knee surgery tomorrow, but I can fix you some after that.
   / Major Modification on LS MT125 3pt Hitch #6
Very smart! My Mitsubishi tractor used the pins to connect the 3 point arms similar to what you did. I'm not quite sure why LS went with the rod method... stronger?
I am sure it is stronger for the non-backhoe tractors; however, with the backhoe attachment, this rear end is really beefed up. I don't see a need. It is made just as heavy as the JD 1025R.
I sent in an email to LS about the problem and my fix. I got this email back. I sent another email asking about the people who already took delivery? I am waiting on the answer. 1508888089180.jpg
   / Major Modification on LS MT125 3pt Hitch #9
Marketing oversight? That is a strange term for a technical problem.
I thought it was unusual terminology also. I just hope they will send out the fix for free if it is a Marketing Oversight. Oversight means the fault is their's. If they fix this problem, I think the tractor will be just about perfect. I have looked it over from top to bottom and I have had nothing bad to say until I got to the 3 pt hitch.
AGT drum mulcher SSFM81 Attachment (A50322)
AGT drum mulcher...
Agco Hesston 4590 Square Baler (A50515)
Agco Hesston 4590...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
40' Sea Container (A50774)
40' Sea Container...
2022 JOHN DEERE 320G WHEELED SKID STEER (A51242)
2022 JOHN DEERE...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
