Major Failure
   / Major Failure #1
brg
Has anyone had a problem with a TC33D New Holland breaking in half. Just had that problem while useing the front end loader. I was not moving so I was not hurt. Just want to know if this is an isolated problem.
   / Major Failure #2
Bummer.
I don't recall a post about a similiar problem over the past three years.
   / Major Failure #3
Have you used a backhoe on your New Holland in the past and if so what type of mounting system did it use to attach to the tractor?
   / Major Failure #4
If you don't mind can you explain how it happened. I'm kind of curious to know the details. Hate to here about something like this happening. /forums/images/graemlins/frown.gif
   / Major Failure #5
I've only heard of tractors breaking in half with 3pt backhoes.. Other than one fellow with a 2120 that had loose tranny bolts..
Soundguy
   / Major Failure #6
Sorry to hear about the failure. /forums/images/graemlins/frown.gif
A friend that I work with had his TC29 break in half.
The castings had been machined to where the flange that bolts the half’s together was less than 1/4" thick. /forums/images/graemlins/shocked.gif
NH replaced the broken parts. /forums/images/graemlins/smile.gif
This happened about 2 years ago while using the loader. He never used a Backhoe with it.
   / Major Failure #7
So very sorry to hear. No, I've not heard of this except in some of the older NH and Ford tractors with three-point mounted backhoes.
   / Major Failure
Bought the tractor used. I am not aware of it ever having a Back Hoe.
   / Major Failure
I was moving a cedar tree. Dump on a brush pile and backed up. The bucket fell and the tractor bowed up in the middle. Broke right behind where the front end loader connects to the body of the tractor.
   / Major Failure #10
<font color="blue">The bucket fell...</font>
Any idea what caused this to happen?
2008 Ford F-350 Altec Service Truck (A50323)
2008 Ford F-350...
JLG 1932E2 19ft Electric Scissor Lift (A50322)
JLG 1932E2 19ft...
Tandem 6 Lug Running Gear (A50774)
Tandem 6 Lug...
Bush Hog TD1500 (A50120)
Bush Hog TD1500...
2022 Kubota KX040-4 (A50120)
2022 Kubota...
Truck Front End w/ Cat Engine (A50121)
Truck Front End w/...
