Maintenance: When Do you........
   / Maintenance: When Do you........ #1
Travis_R
Veteran Member
Livingston Parish, LA
Yanmar YM2500
Spring is almost here! Time for bush hogging!!
My tractor has 1094 hrs. on it now (97' Mahindra 485 D.I.). I changed all the fluids and filters almost a year ago, at 920 hrs. which was when I first got it. So it has 174 hrs. on the "new" fluids and filters. When is it time to do it again??? It set up through the winter, except when I started it to charge the battery.
I just want to say that Mahindra Tractors are VERY tough and dependable. I have not had a minutes trouble or complaints out of mine. I WOULD PUT IT UP AGAINST ANY OTHER BRAND OF TRACTOR IN THE SAME CLASS OR HORSEPOWER WITH FULL CONFIDENCE.
Thanks,
Travis
   / Maintenance: When Do you........ #2
Change oil every 150 hrs. hydralic fluid every 300 hrs. Factory recommendations. Filters at same time.
   / Maintenance: When Do you........ #3
I'm with the last post, factory reccomendations. Also, do you have a FEL on it? I try to grease mine every 10 hours or so (also the front end linkages). A FEL puts a lot of strain on the front end and even if you are not using it, they tend to wiggle around a lot. A little grease can help make sure you get all the lifting power out of it also.
No, I do ot have a FEL on my tractor.
P.S.... I'm not trying to start anything, but my uncle thought about getting rid of his 97' Massey Ferguson 231 tractor and go buy a Mahindra! /forums/images/graemlins/ooo.gif /forums/images/graemlins/grin.gif
2019 BOBCAT S770 SKID STEER (A51242)
2019 BOBCAT S770...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
Mayrath 10 x 32 Auger (A50514)
Mayrath 10 x 32...
New Holland B95 Backhoe (A50490)
New Holland B95...
2017 Claas Jaguar 860 Forage Harvester (A52128)
2017 Claas Jaguar...
