Maintenance Reminder Sheets
   / Maintenance Reminder Sheets #1
jeffinsgf
Veteran Member
Springfield, MO
JD 4410
I just found a pretty nifty feature on Deere's website. If you go to the page linked here:
https://jdparts.deere.com/servlet/c...osearchcontroller.ProductInfoSearchController
Then enter your model number, it will bring up a "Maintenance Reminder Sheet" with the recommended service intervals and the part numbers for most common service items and some common parts that might need replaced. Mine are getting laminated and mounted on the wall in the tractor shed.
   / Maintenance Reminder Sheets #2
Bummer, won't work for the 3*20 type tractors.
   / Maintenance Reminder Sheets #4
Hmm. I can't find where I key in my JD's model # (4600)... do I have to log in first?
-Bob
-Bob
That's weird. I just hit the link twice. The first time, it didn't come up with the form where you enter the model number. The second time it did. I wasn't logged in either time.
If it doesn't show up, go to the left side of the page and scroll down to the very bottom where there's a link for "Product Info Documents".
   / Maintenance Reminder Sheets #6
Thanks. I tried that route, but it shows nothing for my 4600 except filter kits and canopies. If there isn't anything listed in the product document results then that means I'm out of luck, right? I guess that means they don't have it out there for me...
(Thank goodness I still have the PDF of the on-line manual)
Thanks again for the help!
-Bob
   / Maintenance Reminder Sheets #7
Thanks Jeff. Bob I went to the second box down and put in tractor and mdl # and it came up. I scrolled down to find your 4600 and they have the 4610 listed. jb
   / Maintenance Reminder Sheets #8
Thanks, John. The 4610 is pretty similar to the 4600 - but fortunately I also was able to get access to the on-line manuals for my 4600 and the checklist is there too (Mike - rockyridgefarm - posted links to all the manuals a while back... even the one's that JD has taken the links away for).
I like the spreadsheet layout for this... kinda nice, really. I will have to adapt it for my 4600 and use it.
Thanks!
-Bob
SKIDDED CAT MOTOR (A45046)
SKIDDED CAT MOTOR...
WITTIG VACUUM PUMP (A45046)
WITTIG VACUUM PUMP...
2015 Ford F-350 9ft Crew Cab Dump Truck (A44571)
2015 Ford F-350...
CHECO HYDRAULIC GREASE INJECTION UNIT (A45333)
CHECO HYDRAULIC...
2016 Ford Fusion S Sedan (A44572)
2016 Ford Fusion S...
SPRINKLER TRAILER (A45046)
SPRINKLER TRAILER...
