Mowing MAHMX60 mower blades
   / MAHMX60 mower blades #1
kwboxer
Mahindra Max25
New user! Are aftermarket mower blades available for my Mahindra? From my search the blades are over $40 each. I just bought a set of three from a dealer for my fathers Kubota for $52.
   / MAHMX60 mower blades #2
Typically mower blades are fairly generic. You need to know length and mounting hole dia and spacing. With that info I’m guessing the flood gates will open.
   / MAHMX60 mower blades #3
Is it a mid mower or finish mower?
Machio is the og maker of the finish mowers may check out the measurements.. $40 each sounds unnecessary
   / MAHMX60 mower blades #4
I broke a blade once and I was in a pinch. I took a blade into the hardware store with me (doitbest) and matched it to an MTD blade size, but I did have to ream out the center hole to size. I bought 3 so they would all match. The mulching bends/flutes in it was different places than the MAH60 mower blade and was thinner metal. They worked ok, but they dulled fast. And when I hit thick turf, I had to really slow down to keep the inertia of the blades up. Took them off last season and put on a new OEM blade and sharpened the other two originals I had. I now have 2 sets and just swap blades to sharpen at my convenience.
I will be interested if you find an alternate thicker blade with the right flutes. My mower blades get a lot of use.
1262 (A50490)
1262 (A50490)
New Holland HM236 3pt Disc Mower (A50774)
New Holland HM236...
2018 INTERNATIONAL LT625 SLEEPER (A52141)
2018 INTERNATIONAL...
John Deere 333G Hi Flow Compact Track Loader Skid Steer (A50322)
John Deere 333G Hi...
John Deere XUV560E 4x4 Utility Cart (A50322)
John Deere XUV560E...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
