Mahindra TYM connection
   / Mahindra TYM connection #1
yanmars
Veteran Member
I have a Mahindra 4510. I think TYM makes it for Mahindra. It has a TYM ignition key and the engine is made in Korea.
Does anyone know what TYM is comparable to the 4510? thanks
   / Mahindra TYM connection #2
I think you will find the equivalent TYM model is no longer in production but the TYM T443 cab is the new model. TYM did make you tractor but your tractor probably has a Dadong (Kioti) engine and the TYM model has a Mitsubishi engine in it. When did you buy yours and where? All of the "10" series in the Mahindra line up are built by TYM.
Thank you for the information. I bought it off of ebay about 4 years ago, out of a dealer in Pa. From the red dirt in the cab I suspect it came out of a southern red clay area.
Also I had some work done on it about an hour away and I find the temperature gauge is disconnected. I see two loose male contacts but no female ends. Sure would like to get that hooked up again and not have to trailer it back. Any ideas on that would help.
If it helps I paid about $13,500 and it had about 800 hours on it with a front end loader. Thanks
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
2013 Hamm H11i Smooth Drum Vibratory Soil Compactor (A49346)
2013 Hamm H11i...
2019 Ford Explorer AWD SUV (A48082)
2019 Ford Explorer...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
2015 Ford Taurus AWD Sedan (A48082)
2015 Ford Taurus...
2022 Club Car...
