Mahindra transaxle oil
   / Mahindra transaxle oil #1
terraformer
N.E. Mo
Mahindra 3510, Bolens G192/Iseki 1910
I was checking the fluids on my Mahindra 3510. And realized that the oil the rear dipstick was low. Perhaps I have some seepage but more importantly what oil should I put into it. Gear oil, hydraulic oil.
   / Mahindra transaxle oil #2
Most tractors of today have multifunctional usage of the lube; wet brakes, tranny, diff, hydraulics, etc. TSC Premium Trans Hydraulic fluid meets the most stringent requirements out there as best I can tell. Read the applications on the back and they are current and numerous. Since JD is a popular brand, I find that J20C is the spec for the latest requirements for multi-use lube so I ensure that spec is on any fluid I purchase for my Branson.
Mark
   / Mahindra transaxle oil #4
s
In my 2002 - mahindra 4110 its trans/hydraulic fluid . I also have been using Tractor Supply premium trans/hydra fluids
Hey Buck
I checked the fluid again and it seemed fine. I was on a very slight slope....oops.
Turns out the fluid under the tractor was fuel. The fuel filter/shut off sediment trap was leaking. It had been repaired in the past as there was some jb weld on the filter housing at the flange of the plastic part.
I put on a Mercedes diesel pre filter on it and removed the unit. The leaks quit. For a permanent fix I am going to put on a VW fuel filter the same as on my old vw diesel car. It is a disposable can with two barbs for the fuel line and a removable bolt to bleed the system. Cost is less than 20 dollars. I spent more on the jumbo bottle of oil.
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
UNUSED EINGP MSC2030F 20' X 20' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
2014 INTERNATIONAL 4300 INSULATED COLD BOX TRUCK (A54607)
2014 INTERNATIONAL...
Behlen 150 Gallon Premium Stock Tank (A55218)
Behlen 150 Gallon...
New Holland C185 (A47477)
New Holland C185...
