mahindra smokes and shutters above1500 rpms
   / mahindra smokes and shutters above1500 rpms #1
cwshults
floresville, Texas
mahindra, e350di
2001e350di mahindra , runs great till you bring the throttle up to the 540 PTO mark or past, will sputter with smoke and can smell diesel from the smoke, fuel filters are new, drop below those rpm's runs great even under a load , any ideas what would cause this?
   / mahindra smokes and shutters above1500 rpms #2
How's the air filter look is there a restriction in the air supply?
   / mahindra smokes and shutters above1500 rpms #3
Have you bled the air out of the fuel system?
Bled air out of fuel system, air system seemed fine
   / mahindra smokes and shutters above1500 rpms #5
Have you changed the fuel filter and checked for water in the tank?
   / mahindra smokes and shutters above1500 rpms #6
I would check for obstruction the fuel line if the above did not work. Also is the fuel filter connected correctly?
   / mahindra smokes and shutters above1500 rpms #7
Does your smoking and shuttering look lik this?
[video]https://skydrive.live.com/redir?resid=932897728B6597E9!294[/video]
   / mahindra smokes and shutters above1500 rpms #8
Don't have a Mahindra, but it sounds like you are over fueling or have an air restriction. If the there is no restriction in the air intake system (check it thoroughly), I would suspect the injection pump/governor or whatever controls it if it's not mechanically governed.
I will check for restrictions in the fuel and air systems, I will post what i find, thanks for the help guys
   / mahindra smokes and shutters above1500 rpms #10
Did you ever figure out what the problem was ? I think you jinxed me 'cause mine is doing it now...not a big deal 'cause I'm turning her in for the 50 hour check, couple of other minor problems as well, one zerks fitting doesn't want to take grease, etc...warranty is a wonderful thing !
Just wanted to know so I could pass on to my dealer...
Thanks in advance,
Rich
City of Lakeland (A51691)
City of Lakeland...
2018 RoGator RG1100C Sprayer (A53342)
2018 RoGator...
18in Wain-Roy Tooth Bucket (A51573)
18in Wain-Roy...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
