Rcole
So this may be long thread but I need help diagnosing a problem and a little backstory may help. I poked a hole in radiator and didn't realize it until tractor overheated (temp gauge not working). Replaced the radiator and all was well.
After about 15 hours on the tractor with a 10' bushhog it suddenly started loosing power and blowing a bit of white smoke. This has happened before and just needed new fuel filters so I replaced filters and while I was at it cleaned the fuel tank and replaced the strainer. I also pulled all the fuel injectors, broke them down and cleaned them. All are misting as they should be. I checked using the screwdriver technique and all seem to be popping when tractor is running. Still no luck.
The tractor starts and idles fine. You can run it up to about 2000 rpms before you start to hear the miss and get some smoke. It will max out at about 2500 rpms.
This got me to thinking blown head gasket or warped head from the overheating. There are no detectable bubbles in the radiator, no leaking coolant, and no discoloration to the oil but at this point I went ahead and replaced the head gasket anyway. Also I checked for warping with a straight edge and could find none, as well as no visible cracks. I did not have the head pressure tested or use any dye detection. Reassembled and still have the same issue.
The smoke coming from the exhaust at high throttle is minimal and almost undetectable - just a bad miss. I also notice at full throttle, while the gauge tops out at 2500 rpms it has a jump in the needle.
Any thoughts would be appreciated.
