Mahindra.....No Drama
   / Mahindra.....No Drama #1
BobG_in_VA
Veteran Member
Central VA, USA
Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
Well,,, couple of things...for the first time that I can remember, here in central VA the temps from last Friday till today have not seen a minute over the freezing mark...further, on Sunday and Monday mornings, it was -1 degrees..(I keep the 135 Massey in the "basement" garage for pulling the snow plow)..and the Mahindra 6000 sits in the pole shed..yesterday around 10am, I decided to see if that unit would fire up... it was all the way up to about 20 degrees...I turned the key to "on" to cycle the air heater (direct inject..so the intake air is heated), when it cut off I hit the starter...fired right up...so... again NO DRAMA... hope all are staying warm... regards, BobG in VA
   / Mahindra.....No Drama #2
Good for you, we don't have the cold problem in my part of Texas, kinda glad about that also.
   / Mahindra.....No Drama #3
This past Sat. morning it was 3 here in north central Tn. but I didn't try to start my tractor. However I have little doubt it would have if I had so wanted to. Just a week or so before it was in the 20's and did need the tractor and I hit the glow plug mode 1 time and started it before the timer quit - on the almost 13 year old Interstate MHP-31 battery in it. My Mahindra has had it's share of problems in 15 years but starting in any conditions hasn't been one of them. I have started it before when it was in the single digits with just 1 cycle of the glow plugs. My tractor has lived it's full life completely unprotected out in the weather too (and looks like it !!).
23222 (A50323)
23222 (A50323)
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2003 Lexus LS 430 Sedan (A50324)
2003 Lexus LS 430...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
