Mahindra Max28XL Starting Problem
   / Mahindra Max28XL Starting Problem #1
no1papajohn
Natural Bridge, VA
Mahindra Max 28XL, Ford 8N
My 2012 Max28XL will not run after I release the key from the cranking position. It will run as long as I hold the key in the cranking position.
I did this once before but after several tries, it kept running.
Ignition switch is good because when in the on position, dash gauges come on the warmer cycles.
Any help for a newbie member would be appreciated.
   / Mahindra Max28XL Starting Problem #2
Theres a start and a run relay.. sounds like the run relay went "kaput"..
   / Mahindra Max28XL Starting Problem #3
Fuel pull solenoid is failing. (hold coil) :eek:
   / Mahindra Max28XL Starting Problem #4
Sounds like you need the fuel solenoid, the start winding turns on the fuel while cranking and the hold circut takes over when you release the key to the run postion.
Thanks for the info. No manual, can you point me to the gadget?
Thanks for the explanation of how it operates as well as what I should check.
   / Mahindra Max28XL Starting Problem #7
Will, most likely need a new one. Look by your oil filter - cylinder looking with wires... tight spot but easy replace. I had exact problem / symptoms as you describe.
   / Mahindra Max28XL Starting Problem #8
Its to the left of the injection pump.. looks like 1/2 a soda/beer can..
MEASURE how far its turned in.. some people have a hard time reinstalling them..
   / Mahindra Max28XL Starting Problem #9
Here’s a picture from a Mitsubishi manual believe you’d should be similar. Mahindra had problems with the solenoid on a number of the max tractors and replaced them under warranty. Might want to check with the dealer
   / Mahindra Max28XL Starting Problem #10
Good info about the warranty Don.!!!
I don't know why they go thru all that "measuring" nonsense..
Start the engine.. screw the sol. in SLOWLY until the machine shuts off.. lock it down..
plug it in, start & stop the engine w/ the key.. {check your work} easy peazy..
2023 FG INDUSTRY STE 35SR MINI EXCAVATOR (A51222)
2023 FG INDUSTRY...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
CFG MH12RX Mini...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
