Mowing Mahindra Max22 midmount mower questions
   / Mahindra Max22 midmount mower questions #1
MahindraMax22
St. Marys
Mahindra Max22, Ingersoll 4018
I am thinking of buying a midmount mower for my Max22. I have a loader on the tractor. How much ground clearance does the mower have when it raised all the way up? Second, is the mower easy to put on and off? Can I use the 3pt when the mower is mounted on the tractor?
   / Mahindra Max22 midmount mower questions #2
I have a mmm on my max and I really like it. However it does not leave much ground clearance. Maybe 6-8 inches. Not sure what you want to use the 3 pto hitch for but that's what controls the mower deck so if it's lowered all the way the deck will drop down. Whenever I want to use my fel,bh or 3 pto attachment I take the deck off. Only takes me about 10 min max to get it on and off. Made some small wooden ramps to help drive over the deck on concrete so it doesn't scoot around. My only issue is that the grass chaff tends to block the air inlets and the tractor can overheat if I don't keep an eye on it
   / Mahindra Max22 midmount mower questions #3
clearance is Ok - but after i initially had it on i decided to remove it since i rarely use it and i use the bucket 99% of the time. it is Ok to get on and off. not easy but not that bad either. i have no back end equipment so never tried using something re: 3pt with mower on. i have some tighter areas and some hills and little uneven patches so i keep the mower off unless i need to use it. (need to hook it up and use it once or twice this year to keep it moving - the parts that is.) i bought it as a backup and it has come in handy.
   / Mahindra Max22 midmount mower questions #4
On my MAX26 HST there are two clevis pins (one on each of the side of the mmm hangers) that hold the mmm in the up position so that you can use the 3pt hitch. I am not sure if the mmm mounting on a 22 would be designed the same. I have had my mmm for a couple of months now and like it. It can be attached / detached in 15 minutes at most.
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2016 FREIGHTLINER M2 REFRIGERATED BOX TRUCK (A51222)
2016 FREIGHTLINER...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
Homemade Water Trailer 1100-gallon tank (A52128)
Homemade Water...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
