Mahindra Max 24hst runs but white smoke!!
   / Mahindra Max 24hst runs but white smoke!! #1
Foxxygrandpa24
Mahindra Max 24 HST
TractorByNet Forums
F
Foxxygrandpa24
New member​
So I've had my Mahindra Max 24 at work doing a little loader work for a concrete project. All has been great until it started getting a little hard to start. Worked all day and throttled fully down after letting it sit and cool off for 10 min and it died before I could hit the key. No huge problem, took the battery to a local shop, load test came back no good so I swapped it out with a new one. Perfect! Fired right up next day and ran with no issues at all until the last 3 loads of dirt. Started puffing white and kind of sounds like it's missing at full RPM. I babied it to try and get those last 3 scoops checking my gauges constantly to ensure it wasn't over heating. 2 scoops later it ran itself to full RPM from half and wouldn't shut off with the key. It will fire up beit a little slow still and it will run but it still sounds like it has a miss or something and it will smoke our shop out with white when it NEVER really even use to smoke at all.
Things I've tried:
*New battery
*New air filter
*New fuel filter is on the way
*Pulled the glow plugs to inspect them and tightened the bus between them
*Fresh oil
*Pulled the fuel shutoff solenoid and it works just as it should
*Checked my grounds
*Checked that charging system is working
   / Mahindra Max 24hst runs but white smoke!! #2
Check the injectors..
It sounds as if u have a stuck nozzle..
Start the engine, get it smoking and loosen the line at the injector 1x1 retightening as u go..
Your looking for 1 that makes the smoke go away..
and that’s the troubled injector or cylinder..
Good luck
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
