Mahindra MAX 24 steering pivot seal replacement.
   / Mahindra MAX 24 steering pivot seal replacement. #1
aapuzzo
Mahindra Max 24
I was able to get the assembly apart and replace the seal however I am having trouble getting it back together. There are pressed bearing on both sides of the shaft one at the top and the other at the bottom. I was able to remove them using a center punch. Is there a trick to putting it back together? This is the vertical shaft assembly that is behind the hub.
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2018 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
UNUSED FUTURE RC CEMENT TRUCK TOY (A51243)
UNUSED FUTURE RC...
EZ-GO Electric Golf Cart (A50324)
EZ-GO Electric...
