e1440
High,
I'm a new member, looking at purchasing a sub-compact tractor. 75% lawn (3-4 acres), 20% 3-point work (gravel driveway/garden) and 5% loader work (snow removal/landscaping). Have spent months researching every brand out there, all have their +/-'s. it seems most of the big name"s have either, compromised their tractors by going using aluminum rear axles housing's, smaller displacement (higher RPM's), or plastic materials (hoods/fenders) and very complicated self attaching implements (what happens when it wears out). After all the research, it seems Mahindra has stayed true to what I consider a tractor, I'm not looking for a car that is liter for some reason or a machine that is over engineered. I'm looking for a solid, heavy duty (cast steel frame/axle housings), hand fabricated mower deck, simple tractor that is a tractor. That being said, can anyone give me any impute as to why I should consider any of the other brand over Mahindra? There seem to be limited conversations, when you compare Mahinras build quality, performance, simplicity. It seems the only performance issues are less HP, 3-point hydro. control, and a smaller operates station. Yet when it came performance numbers I had to jump up one or two sizes (24,26,28 HP) in the other brands to get compatible performance, and you still have aluminum verses cast steel.
So again can anyone help me, am I looking at the wrong info., or the wrong way.
Thank You
Thank You
