Mahindra E350-D1 front spindle removal
   / Mahindra E350-D1 front spindle removal #1
double hunter
Ford 1715
I just got a Mahindra E350-D1, front left spindle is seized up,,big time, I have taken the steering arm off the the top, I think it should just drive straight down, please correct me if Im wrong, this thing is so seized I had to put a 6' cheater bar on the axle just to move it back and forth, tried working some PB Blaster down into it, any suggestions greatly appreciated
Thanks for the info, went back out and put a little more PB on it,,gonna let it set and try it again in the a.m. goona get my grandson to work it back and forth while strike,,we'll see
Well me and the boy got this loose this morning, it helps a lot when someone is moving it back and forth, we also greased it as it was moving down, very slowly I might say, just about the time the spindle got even with the housing it all loosened up, we greased it liberally put it all back together and we are back jn business,
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A50323)
2017 Mack GU713...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
