Rotary Cutter Mahindra Cutter Gearbox
   / Mahindra Cutter Gearbox #1
Mulemamma
MO Ozarks
Mahindra 2816 Gear
I cannot find a manual on the Mahindra cutter I bought a couple years ago. I really need to check the oil in the gearbox. I'm totally new to tractors & implements. There is a top side screw that comes out to apparently check the oil. I stuck my finger in & felt no oil. Is this where I fill it? Pretty confusing without a manual.
Thanks.............Mulemamma
   / Mahindra Cutter Gearbox #2
If its about 1/3 of the way up from the bottom, yes. Fill to the hole with the box level.
larry
   / Mahindra Cutter Gearbox #3
Here is a link to the Kodiak site. I believe their rotary mowers are manufactured by Mahindra. This is a link to the manuals for the rotary mowers, you can download and save the manual or print it if you want. KODIAK MFG., Inc.
   / Mahindra Cutter Gearbox #4
80/90 WT OIL
Boone
I'll check this out....thank you!
Let me take a big guess here....the manual is not very informative; the bolt on the top side of the gearbox is labeled the pressure/relief valven (prv) and assume it is the fill/empty hole; therefore, I fill (on a level surface) to where it runs out the bolt hole/prv. Okay another question, there is a grease fitting on the pto that hooks up to the clutch that is a 45 degree fitting, but almost entirely impossible to get the flex grease gun onto. It really needs a 90 degree fitting, but no way to get to it to exchange it out. What can I do? I've tried posing questions to the dealers via phone, but they don't seem to be able to answer my questions. Thanks............
2012 Killbros 110 Grain Cart (A50514)
2012 Killbros 110...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
Portable Creep Feeder with Gates (A50515)
Portable Creep...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
2016 MACK CXU613 DAY CAB (A52141)
2016 MACK CXU613...
