Mahindra Clutch
   / Mahindra Clutch #1
for instance John
Charlestown, NH
Mahindra 7520
Have Mahindra 7520 with not a lot of hours on it 125+/-. and the clutch is giving me problems! Seems it takes maybe half hour of warm up+ in summer, (and even forcing the thing into gear) before the clutch finally starts to work!! Fluids full-adjustments adjusted!! Not really interested in bringing it to the dealer, he want's arm and leg just to come and get it and look at it, let alone fix it!
Anyone have this problem and or have knowledge to repair same?
Thanks!
   / Mahindra Clutch #2
Thanks!
:welcome: to TBN. John, unfortunately I can not help you,:( I have not had this problem with my 7520. :D You should probably try posting this in the Mahindra owning and operating forum. There are a few of us that have 7520's, hopefully someone can help you out. :thumbsup:
   / Mahindra Clutch #3
Sounds like your clutch is sticking. If it is. then block the clutch pedal down right using the tractor should help. Maybe the guys in the Mahindra forum will have a better idea to deal with a sticking clutch.
   / Mahindra Clutch
Thanks guys, will do! Thought I was in Mahindra forum, guess it time for glasses!
2011 PJ Tilt Deck Gooseneck Trailer (A50514)
2011 PJ Tilt Deck...
2008 Ford F-250 Ext. Cab Pickup Truck (A50323)
2008 Ford F-250...
20' Sea Container (A50774)
20' Sea Container...
2013 International Day Cab Semi (A50120)
2013 International...
2014 Ford F-550 Altec AT37G 37ft Bucket Truck (A50323)
2014 Ford F-550...
2013 Ford Focus Sedan (A50324)
2013 Ford Focus...
